accelerator pedal sensor
Old Sep 6, 2025 | 12:19 PM
oceanguy's Avatar
Default accelerator pedal sensor
Not having much luck getting responses on my threads, but I'll try again. my 2014 town and country 3.6 vvt seems to run fine but out of nowhere it will go into limp with many multiple codes. It has a new battery, alternator, throttle body and accelerator pedal, but still getting the red lightning bolt and limp intermittently. Reading the voltage as % with my scan tool, the accelerator pedal sensors D and E have not changed since replacing the pedal assembly. D remains constant at idle at 8.24, but E bounces back and forth between 4.2-3.5 and flashes 0.00 for milliseconds. Should there be the E sensor variation? is it possible that with enough flashes to 0.00, the ECU throws limp? If the pedal assembly was changed out and readings are exactly as before, would the ECU itself be suspect?
Old Sep 6, 2025 | 12:58 PM
oceanguy's Avatar
update on this...just test drove. got 0420 and 0430 pending, then cel with 0420 set as well as pending 0128 (t stat coolant temp too low), 0301 misfire, 2804 transmission sensor B intermittent....no limp yet but guessing that;s soon.
oceanguy
Aug 29, 2025 12:07 PM
manoowar2
9
Aug 6, 2021 12:01 PM
fatzcatz
Nov 11, 2020 12:59 PM
Restored
Aug 27, 2020 05:52 PM
Lasershop
Aug 9, 2013 04:58 PM
