Alarm control unit
Old Nov 29, 2017 | 02:48 PM
yableep's Avatar
Default Alarm control unit
Hi Everyone,
Does anyone know the location of the alarm module?
Also does it needs to be reprogrammed or is it just a swap?
Thank you
Old Dec 2, 2017 | 11:37 AM
Vonhofinvule's Avatar
If you mean the siren/sounder unit it can be found under the left hand headlight and can usually be switched from one vehicle to another without reprogramming. Though disconnect your battery before unplugging your old one, if not this can set a fault in your BCM.
As far as I'm aware the rest of the system is controlled via the BCM which does require reprogramming if replaced.
Old Dec 2, 2017 | 01:45 PM
yableep's Avatar
Thanks for your answer.
So far as I know there are several different modules, 1 is the BCM, but also there is a control module for the alarm and immobiliser.
I already looked and can buy a replacement for about £60, just don't know where it is located, someone said it could be behind the steering wheel fairing or behind the cover of the drivers door.
It's a thatham Cat 1 alarm.
Old Dec 3, 2017 | 11:05 AM
I had a problem with mine a few years ago and tried to track down a replacement module, however, everything I saw advertised was in fact the radio receiver for the remotes, but they were advertised as alarm module. However the only reason I knew that was because mine had been replaced before I purchased my van and the old receiver had been left in the glovebox. This I believe is behind the steering cowl.
Finally the issue was tracked down to a faulty siren.
Old Dec 3, 2017 | 12:40 PM
yableep's Avatar
Interesting, someone said to me not too long ago that there might be an issue with the backup battery.
Do you know where the siren is located?
I know that the horn is under the passengers side front light, but I couldn't see the siren.
Old Dec 6, 2017 | 10:14 AM
Hi, you have to remove the left hand headlight because its almost directly under it. Not sure about the backup battery. If I recall the siren is sealed but I could be mistaken as I didn't really look to closely.
Old Dec 6, 2017 | 11:46 AM
yableep's Avatar
Thanks,
Will check it out, last time I took out the light unit, I couldn't see any siren under there.
Old Dec 7, 2017 | 11:39 AM
Found this, which may help.
Old Dec 7, 2017 | 02:50 PM
yableep's Avatar
Thanks, will have a look.
marty1966
Apr 2, 2018 04:32 PM
Huggy59
Oct 17, 2011 06:23 AM
stoneyh1
Oct 7, 2011 09:34 AM
markseb03
Jul 30, 2009 12:58 PM
alan
Nov 19, 2008 01:22 PM
