Anyone know what this is and which is boost pipe
Old Mar 8, 2016 | 01:40 AM
dieselvoyager's Avatar
Just get some hose like this , https://www.festo.com/cat/da_dk/search?query=pun
you also repair the old with some heat shrink tube or fuel hose to connect the broken pice just to solve problem now.
Old Mar 8, 2016 | 07:33 AM
Having a looksee today but rain temp stops play. Right the top pipe on the valve goes to the bulkhead which is actually the Vacuum brake assist reservoir tank. The other pipe must go to the EGR. I however found a problem on mine where the pipe coming from the tank is kinked even though there is a rubber elbow joint at it. Too short a pipe is causing this. So my EGR is as you would say isolated. Battery requires removal to gain access to this area.
Oh and I found mice nest under the engine cover...
Ok, smallbore pipe is 3.69mm and my kinked elbow is getting Vacuum through it but looks damaged.
Attached Thumbnails Anyone know what this is and which is boost pipe-20160308_124234.jpg
Old Mar 8, 2016 | 08:27 AM
darkcild101's Avatar
Thanks Goggs.
Mice nest They must jump off the car before a journey otherwise the temp in engine bay would cook them alive
Old Mar 8, 2016 | 01:00 PM
Either Silicone pipes or....Halfords have Vacuum hose in 1 meter lengths at £5.69 with 3.2mm bore.
Or how about a 10m length of cotton overbraid hose with 3.5mm bore from fleebay under "VW Golf Scirocco Corrado Turbo Vac Hose 3.5mm CA26" for £14.99.
Its a case here of dump the elbows and fit the hoses direct with nice loops from the valve and brake assist tank. Enie minie moo what should I chose...
Hank1946
Jun 26, 2009 10:00 PM
AgEnT
May 13, 2008 08:22 AM
Brandon
May 20, 2007 11:31 AM
streetlegalboi
Oct 24, 2006 06:19 PM
TandC
Mar 12, 2006 01:02 AM
