Beep on start up
Old Feb 7, 2013 | 12:29 PM
S6Voyager's Avatar
Default Beep on start up
Hello,
I was just wondering if it is normal for a single beep to sound just after the car is started, no warning lights or anything, just had the car put through a diagnostic reading and no faults come up thank god!!!!!!!! But still this beep???
Any ideas??
Old Feb 7, 2013 | 02:57 PM
Hodges710's Avatar
maybe the bulb for the tpms system is out and you have a tire low on air, just a suggestion
Old Feb 7, 2013 | 03:48 PM
S6Voyager's Avatar
Being a new boy what's the tpms system? Would this not have shown on the diagnostic test? I take it should not just beep then!! Lol
Old Feb 7, 2013 | 07:07 PM
Hodges710's Avatar
Its your tire pressure monitoring system and im not sure of given years but on my 07 T&C, it beeps per tire that is not within the range of proper air press. I thinks its 3 lbs too. I m not 100% on this but i dont think this would show up on a code search, if it would, my suggestion is wrong and i would also be educated if someone else chimes in with more info on the matter.
Old Feb 7, 2013 | 08:07 PM
Hello,
Any ideas??
- its normal to beep after its done its own diagnostic checks every time you put the key in, and turn the ignition on
- whether it beeps after its started or not depends on how quickly an individual starts the car after turning on the ignition
- try turning the ignition on and .. .. waiting 60 seconds or so for it to do its checks and beep - what happens now ?
Old Feb 8, 2013 | 07:58 AM
S6Voyager's Avatar
Hi, i have tested this and the beep does not come until the engine has started, after about 10 seconds when started, but as i say no warning lights or anything? I just dont like not knowing why its beeping, it could be completely normal but i need to know! lol,
Also my indicator does not always turn off, do i need a new stick?
thanks+
Old Feb 8, 2013 | 09:07 AM
travelmad's Avatar
just a thought,,, do you engage the hand brake?
that will cause a beep.
Old Feb 8, 2013 | 10:45 AM
S6Voyager's Avatar
Hi yes i do engage the handbreak when parked up, and its normally still on when i start the car, so could this be my mystery beep? lol, why does it do this?
Old Feb 11, 2013 | 03:29 AM
travelmad's Avatar
Mine beeped at me the other day, but I also have a service reminder in the overhead console. Or may have been fuel warning.
You have no errors codes, then dont worry about it :-)
aspen13
Dec 23, 2013 05:42 AM
andyclegg
Feb 13, 2013 05:36 AM
davidh6781
Oct 12, 2010 04:59 AM
tanic
Aug 29, 2010 01:04 PM
tcoxcsr
Jun 23, 2008 08:07 PM
