Brakes
Old Feb 13, 2018 | 02:51 PM
Harris5310's Avatar
Default Brakes
Hi everyone! Im in the uk and was wondering if anyone has fitted bigger brakes from another chrysler or of the shelf kits?
Old Feb 13, 2018 | 05:25 PM
Scotsman4th's Avatar
Is it possible? Had to get balancing weights removed from my alloys as they were fitted on the inside for cosmetic reasons (by the fitter). Even 2-3mm thickness was catching on the caliper.
Old Feb 14, 2018 | 01:07 AM
Harris5310's Avatar
Thanks for the reply scotsman4th
what brakes did you fit?
Old Feb 14, 2018 | 02:09 AM
That was with standard discs, calipers and alloys when I got the tyres changed. Had to go back and get the weights removed, and the wheels rebalanced with weights on the outside. There's not much clearence in there.
Others may know of something, but I'm guessing uprated discs and pads might be the best you could hope for.
Old Feb 14, 2018 | 07:10 AM
No idea, because we have no idea what your year is my friend, examples below.
2005
Centre Hole Size (mm): 73.5, Outer Diameter (mm): 301, Overall Height (mm): 39, PCD: 114.3, Thickness (mm): 28, Minimum Thickness (mm): 26.5, Fitting Holes / Studs: 5
2008
Centre Hole Size (mm): 72.6, Outer Diameter (mm): 305, Overall Height (mm): 33, PCD: 127, Thickness (mm): 12, Minimum Thickness (mm): 10.5, Fitting Holes / Studs: 5
Old Feb 14, 2018 | 12:52 PM
Harris5310's Avatar
I have a 54 (2005) grand voyager 2.8 crd
Billiken
Oct 18, 2005 08:39 PM
ChryslerNamedTrixie
Aug 21, 2005 05:58 PM
jojo56
Aug 19, 2005 05:15 AM
PDQ Hemi
Jul 27, 2005 05:55 PM
mdoffroad
Jul 27, 2005 05:51 PM
