Catalyst problem
Old Jun 19, 2024 | 04:25 PM
Amish Uber Mechanic's Avatar
Default Catalyst problem
2010 Town and country 4.0. For over a year this van has been a nightmare. Been to 2 different garages. 1 being a chrysler dealership. They have changed plugs, wires, sensors, throttle body, egr, O2 Sensors etc. Still having problems. It has gotten better but starting hard. Over the last couple months we have been slowly losing coolant but it's not leaking on the ground and we are not smelling coolant burning off of anything. There is no coolant in the oil either. Is it possible that I have a bad head gasket a d coolant is leaking into the exhaust port and causing an issue with the cat and throwing things off causing it to start hard? It cranks very strong but won't fire until I put the accelerator to the floor for a quick second. After it starts it idles around 770. Drives ok too. Just starts hard
Old Jun 19, 2024 | 09:34 PM
describe your hard start its different for everyone. as for the coolant leak need a pressure tst done to see what's leaking.
Old Jun 20, 2024 | 05:36 AM
Default Hard start
Sometimes it will start right up as it should. Most of the time you turn tge key and it just cranks. Cranks very strong but no fire until I push the accelerator to the floor quickly and then it will fire and idle ok. It is also getting poor fuel mileage. It gives 2 codes and both involve the catylis system. 0420 and I can't remember the other for sure but they both involve the catalytic converter and bank 1.
Old Jun 20, 2024 | 09:54 AM
ok for a p420 plugs, wires, sensors, throttle body, egr, O2 Sensors will not do anything you need converters done
Aciga
Apr 19, 2024 10:14 AM
fsm256
Aug 25, 2023 10:46 PM
PMBennett
Jan 18, 2017 09:14 AM
GCookie
9
Jul 15, 2011 02:24 PM
woman needs help
Mar 8, 2008 01:57 PM
