Chrysler Grand Voyager IV 3.3 Limited (12/2000): "P0171 System Too Lean Bank"
Old Feb 23, 2017 | 10:48 AM
Tobias Claren's Avatar
Question Chrysler Grand Voyager IV 3.3 Limited (12/2000): "P0171 System Too Lean Bank"
Hello.
I have a bug (and other, following extra topics...) in a Grand Voyager IV 3.3 Limited from 12/2000 with ~118,000 miles and LPG.
"P1071 System Too Lean Bank".
What is the most likely cause?
Where do I have to look?
Should I photograph something?
Thanks,
Tobias Claren
Old Feb 23, 2017 | 12:41 PM
Lean must mean lacking fuel in the mix. Like air getting in after the mass flow meter. Have you checked intake manifold hoses/pipes for leaks.
Old Mar 11, 2017 | 12:53 AM
svenne's Avatar
Had the same code and replaced both o2 sensors and problem solved.
Old Mar 11, 2017 | 02:44 PM
Question
Two? These are all?
2 "NGK 6384"?
Could you give me the approximate place?
See Appendix (number and "left" or "right").
Attached Thumbnails Chrysler Grand Voyager IV 3.3 Limited (12/2000): "P0171 System Too Lean Bank"-daimler-chrysler-voyager-3.3-v6-engine.jpg
Old Mar 12, 2017 | 04:46 PM
svenne's Avatar
On my 2002 grand voyager 3.3 awd the first one is on the exhaust manifoild and the other on the catmuffler. Could be the fuel filter to. Bad filter can also give you this code. I changed the filter and replaced all fuelinjectors also. The engine performed better after this and got better MPG too.
Old May 24, 2017 | 09:05 AM
What do I have to check there?
If it is not a defective sensor, then it must have a cause.
Where could the error lie?
I do not use the gasoline fuel injectors. Only at the first 1-2 miles. But this error codes at gasoline or LPG.
Btw: There is a open air sucking hole up left in the cover plate top of the engine.
This is correct? Not for a hose pipe? I f close it with my finger, the engine goes out.
HowieF16
Oct 13, 2014 03:49 PM
marcpilot1
Jan 12, 2014 10:03 AM
97 plymouth
Dec 16, 2012 04:35 PM
66satellite383
Apr 30, 2012 05:39 PM
ettienne
Mar 14, 2012 03:35 PM
