Clunky front end 1999 2.5TD
Old Aug 14, 2012 | 04:27 PM
Ming the Merciless's Avatar
Default Clunky front end 1999 2.5TD
Hi , 1999 GV with a clunky front end. Recently replaced the swaybar bushes and links but still have this noise and thud when starting off and occasionally when turning. I`m now thinking suspension struts or at least the top mounts . Anybody have any ideas ? Thanks to all who reply.
Old Aug 15, 2012 | 04:24 PM
booke23's Avatar
A couple of things spring to mind.....A thud when starting off could well be an engine or gearbox mount.
If you still suspect suspension, look closely at the lower arm rear and front mount bushes....although these tend to cause clunks when going over bumps rather than starting off.
Old Aug 18, 2012 | 02:40 AM
Hi Booke
engine mounts had occourred to me as a cause for the clunk i`m getting . So i got a quote from the main stealer for a new set. £500 for just two of them !!! Ouch! I will now look for some equivalent after market items. Do you know of a way of testing the existing ones before i spend out on a new set ? Cheers
Old Aug 18, 2012 | 09:05 AM
booke23's Avatar
You could take the acoustic cover off the top of the engine, grab the engine and give it a really good shove back and forward......you won't be able to shove it nearly as hard as the engine can shove itself, so if you hear anything from the mount it will be a faint knock at best.
Or you could get someone to start the engine and with the hand brake applied engage first gear and raise the clutch to biting point while you watch the engine for excessive movement and a clunk.
Ephata
18
Jun 4, 2014 02:14 PM
MrBiz
Cirrus & Breeze
May 1, 2011 01:52 PM
ijmorrison
Apr 5, 2011 05:11 PM
Ming the Merciless
Mar 2, 2011 05:11 PM
bigalrockin
Jan 9, 2011 04:27 AM
