CV Joint
Old Oct 16, 2013 | 01:09 PM
sncmaverick's Avatar
Default CV Joint
I have a 2002 voyager 3.3 and i have a tire wobble no matter what speed i am driving in my front left. Could this be the CV joint. I have replaced the tie rods and front left hub. I am trying to find out why i am getting a large wobble with out taking it to a mechanic.
Old Oct 16, 2013 | 01:15 PM
Tyre wobble sounds like a knackered tyre, having ply's coming apart inside. Dunlop tyres are bad for that, after being kerbed or run flat.
Old Oct 16, 2013 | 03:57 PM
its a full wobble you can feel the tire actually move back and forth. and they are brand new tires within the past month. Could that big of a wobble still be the tires?
Old Oct 19, 2013 | 06:02 AM
Reverse around wheels, front to back and see what ensues, to eliminate tyres/wheels.
Old Oct 19, 2013 | 03:50 PM
Raptor 07's Avatar
Reading this British slang is half the fun of coming to this website. We lived in Norfolk for 5 years many moons ago. This site is a constant reminder of the great times we had while there.
snc...- Have you checked the control arm bushings?
Old Oct 20, 2013 | 09:28 AM
Leedsman's Avatar
New tyres inside the last month you say? Were they balanced properly? And did this "wobble" come about just after the new tyres? Jack the wheel off the ground and feel for any looseness when pulling the wheel one hand on top one hand on bottom. This should show a loose or knackered wheel bearing. I don't know this car's type, but most have a taper-roller bearing and castle nut that can be adjusted in the standard way.
Has a wheel been bashed against against a kerb unbeknown to you causing it to be bent? You can check easily while wheel is off the ground.
Otherwise you're going to need to check every ball-joint etc. to do with the steering.
CV joins can be checked easily, there should be no play at all in any position of the steering wheel. Try turning the input shaft while holding the wheel tight -- there should be no play at all, again in any position of the steering wheel.
Leedsman.
Mcex
Sep 24, 2014 11:44 AM
chryslervan
Mar 1, 2011 11:28 PM
bjkroll
Mar 9, 2010 08:41 AM
tk1780
May 21, 2008 08:05 AM
jakefree
Jan 27, 2007 07:36 AM
