'01 T&C tripod joint clunk or clank
Old May 13, 2008 | 09:52 AM
tk1780's Avatar
Default '01 T&C tripod joint clunk or clank
When I shift out of park into first or reverse I hear a clank. The car drives fine and shifts fine while driving.
I had a '99 Gr Caravan and had a similar noise and it turned out the half axle bolts had come loose and there was some play.
However, the '01 is a different set up. There is a tripod joint next to the differential or trans output.
The noise is coming from either the passenger's side tripod joint or next to it in the differential or trans output. If I rotate the half axle, I can hear the noise.
Anyone else have this noise
Old May 21, 2008 | 08:05 AM
tk1780's Avatar
Default RE: '01 T&C tripod joint clunk or clank
Went to the dealer. It turned out that the nut holding the half axle on was loose on both sides.
Can't imagine how this happened. Must have been the brake job people. Dont' know why they did it but oh well.
Mcex
Sep 24, 2014 11:44 AM
BenjaminA
Jan 10, 2012 04:14 PM
chryslervan
Mar 1, 2011 11:28 PM
bjkroll
Mar 9, 2010 08:41 AM
jakefree
Jan 27, 2007 07:36 AM
