CV-joint dis-assembly
Old Apr 14, 2019 | 03:14 PM
Thomasx's Avatar
Default CV-joint dis-assembly
Hi
I've got a 2008 Town Country with a bad wheel hub front left that needs to be replaced, but the CV-joint axle is really stuck in the hub, removing the drive-shaft from the CV-joint would make things easier pressing the CV-joint out of the hub.
Is it possible to remove the drive shaft from the outer CV joint, with destroying anything?
Thanks!
Old Apr 14, 2019 | 05:20 PM
REBEL59's Avatar
With the axle nut still on but loosen'd to protect the threads, did you try a sharp "rap" with a large hammer after spraying a good (PB Blaster) penetrating oil to the spline area?
anwaypasible
Nov 3, 2009 05:57 PM
gareth111278
Nov 22, 2008 06:39 AM
bumu
Feb 18, 2007 01:44 PM
peteats
May 3, 2006 12:23 PM
peteats
May 2, 2006 07:20 PM
