Door adjustment...
Old Mar 19, 2014 | 03:27 PM
Merlecollins's Avatar
Default Door adjustment...
Hi all,
My wife had the misfortune of the wind blowing the drivers door out of her hand this morning.
When it is closed now the top of the door does not close properly and we are getting wind noise
The top of door seems to be be proud of the roof by about 5 - 10mm.
Has anyone else had this problem and is the door easy enough to adjust or could the hinges be bent?
Old Mar 19, 2014 | 04:02 PM
Sounds like either or both the door frame or body upright box section is buckled outwards due to door flying open....You'll need a body shop to sort that, or a bit hammer action after removing door.
Old Mar 19, 2014 | 04:23 PM
- I've watched terrified on many occasions while a 'body-shop' wallah puts his boot on the bottom and yanks with all his 25 stone on the top
- and the door miraculously springs back into line with prefect 'gapping'
Old Mar 19, 2014 | 05:17 PM
Thanks fellas. I have a bodyshop not far away, i'll nip it along to them for a look.
Old Mar 19, 2014 | 06:36 PM
Wiscodisco's Avatar
Not as terrifying when doing it yourself.
I've done this to a couple of my cars with great success. A little bit of elbow grease and a couple minutes of your time and you can bring your door gap back to perfect.
Old Mar 19, 2014 | 07:00 PM
- yep - all metal has a memory of sorts
Old Mar 20, 2014 | 07:04 AM
They do that all the time in "American Hotrod" (They're still showing repeats on Quest)
Old Mar 20, 2014 | 08:58 AM
tfb's Avatar
tfb
bodywork is not really my forte, but a good yank on the top of the door will probably pull it back to shape.
Regards
Richard
Old Mar 20, 2014 | 11:07 AM
Regards
Richard
- I've seen a few Voyagers with an out of line front door
- .. .. but is it ?
- if you look down the roof line it plays tricks with your brain
- its not the front / top / out, but the rear top in ..........
- in fact the back slider is pulled in too far by a good 1/4"
So the front door is ok - its the 8mm locator peg in the back door that has been moved and needs to be readjusted to bring it back in to tolerance with the roof line. Most often this issue is accompanied by a noticeable onset of wind noise at spped from the slider in question.
silentdub
Apr 24, 2015 08:27 PM
chase950
Cirrus & Breeze
Sep 23, 2007 12:15 PM
chryslerguy2006
Aug 11, 2007 02:55 PM
69roadrunner
Jun 26, 2007 01:45 PM
GO TOPLESS
Sep 21, 2006 10:49 AM
