Driver door electrics not working
Old May 20, 2014 | 11:15 AM
odiferis's Avatar
Default Driver door electrics not working
hi all, ive just got hold of a voyager and im stumped as to where the relay is for the drivers door electrics. although the central locking switch works, all of the window switches click when pressed but nothing happens. ive checked the fuses and all is good and have replaced the switchs, i just cant seem to find the relay for the windows to see if this is out and needs replacing. another common fault is the key fob not working for the central locking so im having to do it all by key, must get another in case i lock this set in. any ideas on the window relay issue would help me out heaps and get me some brownie points with the wife.
Old May 20, 2014 | 11:32 AM
Check the wiring leading to the door. The flexing of that wiring bundle sometimes results in broken wires.
Old May 20, 2014 | 11:37 AM
odiferis's Avatar
done that one, i was hoping it was as simple as that but sadly no. I just hope its not as big of a problem as the cotrol board.
Old May 20, 2014 | 02:10 PM
Raptor 07's Avatar
I'll need the model year (not the plate) so I can check diagrams.
Old May 26, 2014 | 05:00 PM
odiferis's Avatar
it was born in 2000.
Old May 27, 2014 | 03:39 PM
Raptor 07's Avatar
Looking at the wire diagram there is no power window relay. Power comes off two PTC circuit breakers (# 9 & 8) on the fuse/relay panel under the dash and straight to the driver's door switch assembly where all the magic happens. If your rear vent windows work then that leaves out the PTCs.
Old May 27, 2014 | 04:45 PM
odiferis's Avatar
The back air vents are also not working, might have to go back to the wiring loom from the fuses to the switches. I will get the breaks working first though, wife needs them more than a window.
Old May 27, 2014 | 05:17 PM
RCSnyder's Avatar
WIndows ...
Motor brushes? Would explain the windows and wings ... and is a common point of failure. However, if everything went an once, I'd probably be looking for a circuit failure in the ignition, perhaps.
Power Locks ...
Your guess is as good as mine.
osaeed
May 8, 2013 01:46 AM
Spenosa
Feb 28, 2013 03:42 PM
barrr
Feb 9, 2010 01:35 AM
volly
Jan 2, 2010 09:32 AM
Seriously?
Oct 13, 2009 10:22 PM
