EGR valve plumbing
Old Jul 11, 2017 | 04:01 AM
fragmented's Avatar
Default EGR valve plumbing
Hi All
Having taken off the EGR valve, cleaned it and refitted I seem to have a
vacuum connection left over with no visible pipe to fit to it.
I know I should have taken a photo before taking it off but ....................
Anyway I've attached a pic of what I have now.
Does anyone have a plumbing diagram or photo so I can what's wrong.
John
Old Jul 11, 2017 | 04:03 AM
fragmented's Avatar
Forgot to say 2007 2.8 diesel with 145k on the clock
Old Jul 11, 2017 | 09:02 AM
andyb2000's Avatar
Hi there,
I've had to do a little fix to one of these two pipes so I know the upper one goes backwards and round to the right of the engine bay. The other goes to the left. My guess is it's gone back inside the trunking.
Here is a pic of the valve on mine and where the pipes go back to initially, hopefully you'll spot them. If not I can probably take a more in-depth photo later of where they end up with a bit of rummaging around!
Hope that helps!
Attached Thumbnails EGR valve plumbing-chr_1.jpg   EGR valve plumbing-chr_2.jpg
Old Jul 12, 2017 | 11:00 AM
Scotsman4th's Avatar
Looked at mines, the pipe you've got on the 3rd one down is for the second one down, that you're missing.
The 3rd one down on mines is blanked off, same as the one in Andys picture.
Old Jul 12, 2017 | 01:42 PM
fragmented's Avatar
I'll swap them over tomorrow and see it that's it
Old Jul 12, 2017 | 02:43 PM
andyb2000's Avatar
Ahh! Good spot Scotsman4th, I totally missed that part.
Hope that's it then fragmented, don't forget to post back on if it's all sorted.
Old Jul 13, 2017 | 02:30 AM
fragmented's Avatar
I'm off to the garage, where it's been for a week, to check it out.
Fingers crossed
Old Jul 23, 2017 | 08:28 AM
fragmented's Avatar
An update on this.
Despite trying all possible options with the plumbing I still get an error code for the EGR.
My mechanic, who is also a friend, suggested I either blank it off or buy a new one.
Went for the blank off - this didn't cure it either so he remapped it taking the EGR out.
Still not running right.
It runs fine on the flat or downhill but any sort of incline and the engine shudders and vibrates, I can accelerate through the vibration.
If I floor it, clouds of black smoke.
If this problem indicates anything to anyone please let me know.
Old Jul 23, 2017 | 03:24 PM
Check out Turbo Actuator and hose to it from boost side of turbo.
stevep
Oct 8, 2016 08:25 AM
stevep
9
Mar 30, 2011 09:57 PM
96RedLXI
Oct 20, 2007 01:49 PM
96RedLXI
Sep 17, 2007 09:31 AM
kevinc
Apr 29, 2007 11:51 PM
