Fitting a second thermostat...
Old Feb 27, 2014 | 04:38 PM
  #51
pete@co.uk's Avatar
By the way my car is exactly the same as the one in my Avatar same colour too
Old Jan 28, 2015 | 09:03 AM
  #52
sundowners's Avatar
I have --eventually---got around to fitting a 'second' t-stat------I bought the new stat during last summer.
Apart from travelling without the auxiliary heater running all the time----the fuel consumption (on the computer) has gone from 28 ish to mid 30s and the transmission seems to be smoother changing ?? ---Temp was going over half-way so I took it out today to check it-----I put it in backwards------We are about to go out again so I am hoping it will be fine now
What a fantastic/easy mod---thanks for posting it
Nigel
Old Nov 28, 2015 | 07:38 AM
  #53
Andrips's Avatar
Thanks Leedsman for the mod. I bought the GV 2.8 05 few weeks ago and found out that thermostat is faulty. I ordered the Renault stat and as soon its will be delivered, will try to install.
Thanks again.
Old Nov 28, 2015 | 01:56 PM
  #54
Just checking back my records is this it. One's for a 5 others for a 9..
Attached Thumbnails Fitting a second thermostat...-renault-5-stat.png   Fitting a second thermostat...-renault-9-stat.png
Old Nov 28, 2015 | 03:20 PM
  #55
Vmaxxer's Avatar
My renault stat is still running great in my voyager after 50K km .. great mod this is!
Old Nov 29, 2015 | 12:10 PM
  #56
sundowners's Avatar
been running our 2nd stat. for nearly a year-------I am really pleased with such an easy mod.
Nigel
Old Nov 30, 2015 | 09:33 AM
  #57
Andrips's Avatar
I'm little bit confused about the correct place for the small hole on Renault 5 thermostat.
Old Nov 30, 2015 | 09:37 AM
  #58
Andrips's Avatar
Old Nov 30, 2015 | 10:36 AM
  #59
darkcild101's Avatar
So is the main benefit for those mod better fuel consumption or am i missing something
Old Nov 30, 2015 | 12:53 PM
  #60
Vmaxxer's Avatar
Main benefit is that you don't need to replace a faulty standard stat.
The original stat is located on an impossible spot and is very expensive which makes replacement a major pain in the *** and wallet.
If/when the original stat is stuck wide open (mostly the case) this is a €15,- solution in stead of an at least €250,- repair.
@Andrips.
