Fitting a second thermostat...
Old Dec 6, 2015 | 03:58 PM
  #71
darkcild101's Avatar
Originally Posted by Andrips
never had these arrows on my panel. but I can hear that heater is running, noise comes from underneath
I have not got that symbol either though I can hear the heater
Old Dec 6, 2015 | 04:33 PM
  #72
Andrips's Avatar
Old Dec 6, 2015 | 05:38 PM
  #73
Thanks Vmaxxer,
20 min trip around the town and level back to normal. Will keep eye on the level for next few days.
Now must find how to sort out he webasto issue.
What's often forgotten in GV 'burping' is to put the heat and fan to full whack to clear the heater matrix of any air and allow a full volume flow of water and any air it contains, the blue syphon pipe in your photo is already in the highest point of bleed. Best of luck.
Old Dec 10, 2015 | 02:35 AM
  #74
Tombt's Avatar
Default Jiggle pin
So, I've got the stuck open thermostat issue and going to put in the second one.
Quick question, the stat i've got from my local autoparts shop has a jiggle pin on the flange, I'm thinking this should take care of any airlocking without drilling.
Thoughts???
Tom.
Old Dec 10, 2015 | 07:11 AM
  #75
Thoughts???
Tom.
Wobble pin - direction is pre~determined, the orientation is always 12 O'clock. If you watch the pulse pulse pulse of the return water into the header tank / expansion bottle you will see its not continuous and not under much pressure. So you have a mixture of slack water from the pump and air, the air is always at the top - hence the wobble pin at 12 O'clock. Best of luck.
Old Dec 14, 2015 | 07:58 AM
  #76
Got new thermostat over the weekend. On picture which pipe do i fit into?
sorry for my ignorance
Old Dec 15, 2015 | 12:36 AM
  #77
Andrips's Avatar
I fitted In to the top pipe on the right side (close to the coolant tank).
Old Dec 15, 2015 | 05:37 AM
  #78
Where exactly. The blue or red circle
Old Dec 15, 2015 | 05:44 AM
  #79
Andrips's Avatar
I fitted in to the pipe/tube marked with Red circle
Old Dec 15, 2015 | 06:15 AM
  #80
Vmaxxer's Avatar
3 or 4 pages back there was this picture where you could see the stat mounted
