Front brakes
Old Aug 25, 2013 | 01:54 AM
S6Voyager's Avatar
Default Front brakes
Morning gents,
My front brakes make a terrable noise amd i get a slight judder every now and then from the near side, so its time to change them, still a good bit of meat on the pads and disc but think they have worn unevenley?
I was thinking mintex as know they are good and ive used them on my cars before, but any one got any other reccomrndations? And costs?
Cheers
Old Aug 25, 2013 | 06:12 AM
rodger's Avatar
Old Aug 25, 2013 | 03:26 PM
Sounds like you've got an unworn edge on your disc where the pad skids over it instead of wearing it away.. Can be removed with a hand grinder then finish off with a hand file. That's unless you've got a metal turning lathe that is.
Old Aug 25, 2013 | 05:18 PM
If you live in the north east, I'll skim them FOC for you.
Old Aug 26, 2013 | 04:16 AM
S6Voyager's Avatar
Thanks for your replies gents, there is defernatly a lip on the disc both side so i new that was the noise, you feel like ou wantto be swallowed up by a big hole every time i touch the breaks!!!
Im actually in the southeast but thank you for the offer, i think im going to order mintex disc and pads, just to be safe, they come highy recommended.
Ive got a 2 ton trolly jack and 2ton axel stands, will they be ok to use? I haven had to jack her up before.
Old Aug 26, 2013 | 05:40 AM
travelmad's Avatar
They will be fine.
I did my front discs on the driveway a few months ago
Old Aug 26, 2013 | 07:27 AM
I've got a 2 ton trolly jack and 2ton axel stands, will they be ok to use? I haven't had to jack her up before.
- can't see a jacking problem - per axle
- make sure you 'chock' both the remaining contact wheels
- - try your wind down spare wheel before you start
- - and give the cable a lashing with light slip while you can get at it
Old Aug 27, 2013 | 03:44 AM
TimmyTim's Avatar
Thumbs up
Morning gents,
Cheers
I've just changed my discs and pads on a 2007 GV. I used Mintex pads with MTEC drilled discs. Great set up that stop the car on a 2p piece!... But you have to be carful when pushing the pistons back in as they can be brittle and crack as mine did on O/S/R
thundergod66
Jan 16, 2013 10:56 PM
Gray Rider
Sep 23, 2012 09:02 PM
smileymikey
Dec 30, 2011 05:14 AM
MRytel
Oct 6, 2009 10:22 AM
billbon8
Jun 27, 2008 04:24 PM
