Fuel sensor or pump? Or both?
Old Apr 20, 2017 | 01:42 PM
Vmaxxer's Avatar
Default Fuel sensor or pump? Or both?
My starting troubles after an extended period of parking (8+ hours) especially when its cold are still not over.
I narrowed my search to a problem getting the diesel to the engine from the tank.
So I looked in my Chrysler handbook and found there are several types of Fuels Sensor/Liftpump for the CRD models.
There are Stow and non Stow versions I found out.
But today I was at the scrapyard where they tried to sell me a Diesel sensor WITHOUT a pump just a sensor ...which was salvaged from a 2003 CRD 2.5 (Non Stow$Go).... Why did that voyager have a sensor without a pump?
When I look on Ebay I find all different kinds of Sensor/pumps stow and no stow...
This is so confusing..
I'm afraid I have to look under the car in the tank first to determine which pump I have...
Old May 1, 2017 | 12:38 PM
Vmaxxer's Avatar
My mechanic got the fueltank from under the car and concluded there is no pump in the tank..
It drove me insane because I am sure I can hear some pump from underneath the car and I am 99% sure my car wont start because for some reason the fuel flows back when the car is idel and has a problem building enough pressure to lift the fuel to the engine.
So now what?
I looked under the car myself and found not only a connector for the watersensor but also a connector to a pump in the fuelfilter housing
The differences between petrol and diesel cars tricked me
But now I have to find that part hoping it solves my problem
Old May 2, 2017 | 08:34 AM
andyb2000's Avatar
Hiya,
Yes there are many variations which are really confusing on it, the 2.8CRD (2004/2005 that I have) has the same as you, nothing in the tank, but beside it the fuel filter/water/pump assembly, small drain, water in fuel sensor and this on mine is the only lift pump, but you hear it at initial ignition switch on for a few seconds.
I did a video on mine changing the fuel filter on my model if you want to compare the bits involved, but looks like you've got it cracked now :-)
I have slight starting issues from cold, I have to blip the accelerator whilst turning over and it usually catches after a few spins, bit of a cloud of smoke but it starts, never had a non-start yet but it's obviously the start of a similar issue.
I've changed the filter on mine and no difference so my suspicion is there is a small air leak somewhere in the line (or injector return rail) causing the fuel to seep back down over long periods.
I've not yet identified it exactly, I did the injector leak/return test which didn't reveal a huge amount being returned/leaked by the injectors so I've ruled those out on mine for now.
Good luck!
Old May 4, 2017 | 02:29 PM
Vmaxxer's Avatar
After a few days testing with the new filterhouse/liftpump I am happy to report the car starts pretty quick every morning after a long parkingtime.
Problem seems solved with this.
I hope it stays this way now...
Old May 5, 2017 | 05:15 AM
Vmaxxer's Avatar
%!!$#!%!$%!%#!$%^!#!11%#!%#$%$!45!54!!!!
This morning the car wouldn't start.... AGAIN!
A small "wiff" of brakecleaner and the CRD starts imediatly...
After that car runs perfect and keeps starting very well, every time... until tomorrow morning..
Someone please shoot me..
Princessmobile
Other
Jul 19, 2017 11:09 PM
Darth Menace
Feb 19, 2016 09:16 PM
96BTC
Sep 27, 2010 10:29 PM
paul.siwek
15
Feb 5, 2008 12:56 PM
Jimbo Asprilla
Mar 22, 2007 02:04 PM
