Grnd voyager Caravan 2005 2.8crd- Heater not heating
Old Oct 23, 2021 | 05:36 AM
It probably is the thermostat, it's a common problem on the 2.5 and 2.8, but try blocking off the radiator first.
Edit: Also flush the cooling system but ensure that you use the correct ant-freeze when re-filling and make sure you don't get any air locks in the system. An air lock can prevent hot water flowing through the heater. When re-filling, have the heater set to maximum.
Old Nov 13, 2021 | 03:02 PM
WR28CRD's Avatar
Hi,
Just an update.
Ive changed the anti freeze, fitted the thermostat and also changed the coolant. unfortunatley the temp dial has only gone up by an 1/8!.
I do get high temp when the fan is on low spead but when i increase the air flow the air temprature goes very cold.
regards
maurerdrilling
Jan 15, 2013 02:00 PM
fwincoltsfan
Feb 26, 2012 01:05 PM
sweetlttlpammy
Jan 7, 2010 08:04 PM
simontheburger0
Dec 9, 2008 10:55 AM
keahieggers
Nov 12, 2008 10:20 AM
