How do I replace the starter on a 00 Voyager?
Old Dec 21, 2010 | 07:50 PM
InfoSeek's Avatar
Default How do I replace the starter on a 00 Voyager?
Hey guys!
New here. Can someone guide me as to how to replace the starter of a 00 voyager?
I have tried searching the net for a write up, but can't seem to find a good one. For beginners, most of the write ups don't even mention where it's located.
Thanks!!
Oz
Old Dec 22, 2010 | 06:35 AM
ettienne's Avatar
Do yourself a favor and get a Hayes manual for your vehicle, that will help with many tasks.
Remove the negative cable from the battery before you remove the starter.
A rule of thumb is that the starter is always on the same side as the battery, and there is a thick cable running from the battery + side to the starter. Follow that cable and you will find the starter at the other end. Disconnect the cables - there should the be + cable and one other, and then 2 or 3 bolts and it will slide right out. Take care not to loose the spacer if there is one (that depends on your model). Install is just the reverse sequence.
Old Dec 22, 2010 | 03:32 PM
InfoSeek's Avatar
I checked out the hayes manual, and it didn't really help much with the starter. It doesn't mention where it's located or what kind of tools I'll need, which is really bad, IMHO.
I disconnected the battery to see if I could locate it without jacking up the car, however the red cable from the batter is bound together by a larger black tube that has other wires within and it's really difficult to trace it (red cable) to the starter.
However, I have gone ahead and bought the jack. Its raining right now so I'm going to wait till it clears out before trying to get under and checking. Just for future references I'll try taking pics and post it here in case I'm able to replace the starter.
In the meantime, does anyone know where the starter is really located? Will I be able to look at it once I get under the car??
Oz
Old Dec 22, 2010 | 04:51 PM
ettienne's Avatar
You can see it from the top, in front of the engine where the tranny mates to the engine. Look for the thick red cable going to a round object about 3" diameter.
Old Dec 22, 2010 | 09:37 PM
InfoSeek's Avatar
I tried looking for it from the top but can't really see it. I took pictures though.
Thanks,
Oz
Old Dec 22, 2010 | 09:38 PM
InfoSeek's Avatar
Bummer. I apologize for the quality of the pics... I should have given more spacing between them. Didn't know they would bunch up like that. Is there anyway of editing posts? I can't seem to find the button for that.
Old Dec 23, 2010 | 05:04 PM
InfoSeek's Avatar
So I found the starter. It's the silver cylinder object in the third picture. But I can't figure out how to take it off. The bolts are all the way in the back! The Hayes manual made it seem so easy, lol. Also, I can only see one cable. I took more pictures:
Do I need to take that plate off? It's got 3 bolts attached to it, a connector in the middle, and then 3 bolts on the other side bolted to the bumper. And where is the other wire?
Second Pic:
Another picture of the bolt, which is further than it looks. It's all the way in the back.
It started raining again, I'm going to go back pretty soon, and try taking that starter off...
Old Dec 25, 2010 | 12:09 AM
InfoSeek's Avatar
Well I was able to change the starter, but now something else is happening!
When I turn on the van, there's a rapid clicking noise coming from behind the fuse box next to the battery. What's odd is that the noise continues even after we take the keys out of the ignition. I know it's not the battery because we tried jumping the van, and it did the same thing.
Why is it happening?? lol.
ARGH!!
kkc
Jan 30, 2014 08:39 AM
kobusven
Jul 30, 2012 11:18 AM
jaygr
Mar 5, 2012 10:14 PM
stevelor4
9
Mar 26, 2010 04:48 AM
sundance
Jun 23, 2007 04:05 PM
