I need help!!!
Old Nov 21, 2006 | 10:08 PM
m.squiers1984's Avatar
Default I need help!!!
I have a 2003 Voyager and a few things are going wrong. When I hit even the slighest bump I hear a clunking noise in the front. My heater and A/C only work on high, and I cant figure out which brake pads I need for the front. I called a few auto parts stores for the front brake pads and I got the wrong ones, they look totally different than the ones that are on there now. I have a 4 cyl. without ABS. CAN ANYONE HELP ME ?????????[:@]
Old Nov 22, 2006 | 04:36 AM
webbee's Avatar
Default RE: I need help!!!
Can't say about the brake pads. The clunk is either the sway bar ends or the bushings. The heater/ac blower resistor is shot. Replace and it will work fine.
Old Feb 28, 2007 | 03:54 PM
Prost264's Avatar
I am having the same problem in my Town & Country. When going over the slightest bump I get clunking from the front end. Its been to the shop a few times and no one can figure it out.
Old Feb 28, 2007 | 06:16 PM
sway bar links and bushings are the main deals on new TnC
Old Mar 1, 2007 | 03:42 PM
latreto's Avatar
hello
I think I have the same problem ...... Is it the stabilizer bar or the bushing that fix it to the car?
regards
Rafael
Old Mar 1, 2007 | 06:03 PM
if its the same noise that i heard all the time yep
Old Mar 3, 2007 | 10:54 PM
Prost264's Avatar
Bushings ordered the other day, looking forward to no more clunking at every bump.
Old Mar 25, 2007 | 09:39 PM
Prost264's Avatar
I put the new bushings on and now its good as new, thanks guys.
Old Dec 15, 2007 | 12:00 AM
jeff1960's Avatar
Here's my story:
2003 T & C. Front blower goes directly to highas soon as I start the van.Stays constant on higheven when I turn off the system.Took to dealer and told me the blower needs replacing. Headded thatthe blower is damaging the "blower resister" I found out later it'snot a resister but a "control module")and BOTH need replacing. Told me it would take 5-6 hours because he had to remove the entire dash in order to remove the blower.
I declined the $1,060.00 (yes....one thousand sixty dollars) charge to repair it
I bought a "Haynes" manual. It took me 5 minutes to remove the "resister" (which actually turned out to be a "control module") and1 hour to remove theblower. After reading numerous posts tonight, I'm going to re-install the blowerand put in a new module. I guess they think my last vehicle was a turnip wagon. (Shame is, I paid them $100.00 to diagnose the problem)
As far as the "clunk"......it's the front sway bar bushings. I had a 2000 Grand Caravan, friend had a 99....both were fixed with new bushing. (I did it for 5% costof what the dealer wanted plus my labor)
JamesBraxton
Sep 18, 2011 09:01 PM
s.wilson1978@yahoo.com
Jul 12, 2011 02:19 PM
musicfreak2195
Sep 19, 2008 12:47 AM
ETD66SS
Jul 3, 2005 01:33 PM
nypdalamo77
May 26, 2005 12:41 AM
