If anyone needs help in Surrey UK
Old Aug 8, 2009 | 04:31 PM
pete@co.uk's Avatar
hi mike
the car is in the garage with the exhaust and manifold removed and it will be there till next week
pete..................
Old Aug 8, 2009 | 05:45 PM
Mike213735's Avatar
Good luck, I am sure the car will be completely different (in a good way) upon it's return...
Let us know how it goes.
Mike
Old Aug 13, 2009 | 03:56 PM
pete@co.uk's Avatar
hi all
had the car back and its still has the flat spot ive tried changing the plugs no differance checked the air filter it has a new one, the plugs i took out were black with white cores not oily or anything i was thinking it could be leads or coil pack
pete..............................
Old Aug 17, 2009 | 02:27 AM
pete@co.uk's Avatar
hi all
it was the coil pack and leads now all is well
Old Aug 17, 2009 | 10:59 AM
  #15
Mike213735's Avatar
Great news Pete, glad it's all sorted
Old Aug 18, 2009 | 02:26 AM
  #16
Scruffy's Avatar
Banned
Well done - glad you sorted it out
Old Aug 19, 2009 | 03:51 PM
  #17
pete@co.uk's Avatar
the problems back ive been told it could be the map sensor at fault i havent been able to sort it out yet
pete.................................
Old Sep 8, 2009 | 03:33 PM
  #18
voyager_dan's Avatar
hi you are not far from me in aldershot,i have a issue with my 1998 2.5td voyager ,the problem i have is that the clutch pedal has free movement this is pushing the master plunger but doing nothing slave end
i have been told in the past that it is not possible to bleed the clutch and that it has to be replaced master/slave but having just stumbled accross a old post apparantly this is not the case i want to have a go but am worried that i will end up parting with m hard earned at chrysler,iam a mechanic but have not come accross this type of set up before
your thoughts will be appreciated,maybe i could ask for your help if you have done this before
dan
Old Sep 8, 2009 | 05:24 PM
  #19
glowplug's Avatar
I have posted previously on how to bleed this and even posted pictures
By the way, I am in Camberley if you want to take a quick trip to me I can explain it to you first hand.
Old Sep 8, 2009 | 05:43 PM
  #20
yeah that would be good ,then i can show you the problem see what you think when is good for you ill pm you my number
dan
