If anyone needs help in Surrey UK
Old Jan 17, 2010 | 04:48 PM
  #41
Merlin's Avatar
NO, not going to be alternator. Check your fuses. The ECM (Engine ECU) regulates the voltage if the voltage sense fuse is blown it can't sense the voltage of the battery so it pulses the alternator on and off so the lights do the same.
Old Jan 18, 2010 | 06:03 PM
  #42
voyager_dan's Avatar
could also be alternator ,this needs to be checked as can cause the same fault, check the obvious first and work through
process of elimination every good mechanic knows that!
Old Jan 29, 2010 | 07:30 PM
  #43
BUNNY's Avatar
Default Bunny
Thanks Voyager-Dan changed alternator still the same
Old Jan 29, 2010 | 07:34 PM
  #44
BUNNY's Avatar
Thanks Merlin could you tell me where the voltage sence fuse is please getting desperate now
Old Jan 30, 2010 | 05:39 PM
  #45
Merlin's Avatar
in the fuse box under the bonnet, if I remember correctly it's the fuel heater fuse and the the heater that could well be your fault and making the fuse blow (if it's blown)
Old Feb 5, 2010 | 10:08 AM
  #46
inch high pi's Avatar
hi chaps.
first time poster here, so sorry if its in the wrong place and sorry if im nabbing the thread but i thought i post i here as im near guildford (egham).
my voyager has just failed its mot due to the exhaust blowing. so im going to get a replacement. does anyone know if i need the whole middle and rear section or if i can just replace the middle.
it an r reg voyager.
cheers
rich.
Old Feb 16, 2010 | 02:44 PM
  #47
momoyan's Avatar
Default Alarm Problem
hi
the alarm in my voyager 2.5 crd lx went off , first the battery was flat because of the alarm i think , i charged the battery now i can start the car but i can't stop the alarm even by opening the door , there is as well a noise comming from the fuse compartiment
thanks for your help
Old Feb 16, 2010 | 02:55 PM
  #48
momoyan's Avatar
Originally Posted by Scruffy
Should anyone require help with Voyagers then I'm your man. I am in Guildford, Surrey.
Most importantly I have a fix for the common intermittent starting problems where the immobiliser does not let your start the engine and the instruments go dead.
hi scruffy
thanks for for offring your help
Old Feb 19, 2010 | 11:40 AM
  #49
dcm1971's Avatar
Originally Posted by inch high pi
hi chaps.
cheers
rich.
the exhaust is only in two sections, the Cat and then the exhaust. If you can get someone to fit it, Eurocarparts and onlineautomotive is the cheapest place to source the parts.
Old Feb 24, 2010 | 04:23 PM
  #50
stokesy's Avatar
Default Hi Newbie
Hi Just got a mk2 voyager, could do with a owners manual, is there one on the internet as a guy on fleebay wants a lot of money.
i also have a mk1 that i am about to scrap, so if any one wants any parts just give me a shout
clive
