Issue with radiator fans
Old Apr 26, 2011 | 09:43 PM
strada's Avatar
Default Issue with radiator fans
Hello all, hope you can help with a problem I haven't seen in my searches. Recently I noticed both radiator fans are running on high whenever the engine is running. With key off or in the on position with engine not running the fans don't run, only when engine is running. Does this sound like it could be the relay?
Old Apr 26, 2011 | 10:00 PM
Djinn-n-Tonic's Avatar
Year???? Is the CHECK ENGINE LIGHT ON?????
Old Apr 26, 2011 | 10:04 PM
strada's Avatar
Sorry, I went to edit the post and realized you can't (strange)
It's an '02, no check engine light - temp gauge reads normal.
Old Apr 26, 2011 | 10:30 PM
FAN WIRING...
ok.....Since no C/E lamp...we can reasonably rule out ECT (Coolant sensor) as being stuck High....
Now, PCM controls the fan relay...(Which by the way is a solid state control module...and NOT a little Black Cube) during periods of demand...High coolant temp, A/C /Defrost request...etc.
If it only runs with the engine running....we can reasonably rule out stuck relay..because there is No way for a relay to differentiate "Running Power" from "Key turned ON power"
So we move to the other side of the system....Is the defroster on?, is the A/C on?
At this point...we know that PCM is commanding the fans ON....But why???
Either the PCM is defective.....or something is giving false info to PCM , when no Command is actually required.
Old Apr 26, 2011 | 10:49 PM
strada's Avatar
With engine running, it makes no difference whether the ac, heat, defroster is on/off - both fans run on high.
Old Apr 26, 2011 | 10:59 PM
Un plug the high pressure switch connector at the A/C line. This will disable the A/C. If the fans now behave normally...you can start looking into the A/C related components as the culprit.
jammozzz
Apr 20, 2011 09:51 AM
dajoyner
Feb 25, 2011 05:21 PM
dun211
Aug 22, 2008 02:53 PM
gbeach
Jun 30, 2008 05:01 PM
vlsgmc
Apr 4, 2008 09:26 PM
