Ive lost all instruments and lights in the dashboard
Old Dec 21, 2014 | 03:25 PM
magadu2002's Avatar
Default Ive lost all instruments and lights in the dashboard
hello newbie here
About a week ago i woke up and went out to go to my car. The rear right tyre had lost a lot of air. I thought this would be enough to go to the local fuel station to pump it back up. On the way there i heard a strange noise coming from that tyre so i stopped the car and took a look. The alloy had completely come off the tyre. I drove the car back home but all instruments had stopped working. the needles, the LCDs and the hazard lights had all stopped working. i dont know if this is all just a big coincidence or not. I got home and disconnected the battery to see if that was the problem but the problem persisted.
Old Dec 21, 2014 | 03:28 PM
magadu2002's Avatar
By the way the car is a 1991 2.5 litre diesel limited edition
Old Dec 22, 2014 | 02:43 PM
Something comes up that you need a new instrument panel. Whether its the soldiered joins or the power relay in it.
Like Audi TT's and Renault Mk3 Espaces of the past.
Old Dec 22, 2014 | 02:48 PM
Check for fuse to cluster first.
Old Dec 22, 2014 | 03:00 PM
Try hitting top of dash with the palm of your hand. If it comes back on its a solder issue.
Old Dec 23, 2014 | 11:38 AM
magadu2002's Avatar
thanks i will try all suggestions
Old Dec 23, 2014 | 02:28 PM
Try
if its wiring
Old Dec 24, 2014 | 01:38 PM
Any results Magadu....
Old Jan 3, 2015 | 03:20 PM
magadu2002's Avatar
thanks guys the cluster is now working very grateful
how likely is the rim/alloy likely to be damaged given i drove on it with no air in the tyre
Old Jan 4, 2015 | 02:26 PM
Yes but what was the repair..helps others you see.....
bate1
Jan 3, 2012 08:46 AM
spadez513
Sep 11, 2011 07:10 PM
spritemad
Feb 17, 2011 02:49 PM
97LXIgirl
May 7, 2008 02:36 PM
