lifting 2012 T&C with floor jack
Old Aug 29, 2013 | 10:06 PM
krswen's Avatar
Default lifting 2012 T&C with floor jack
Where can I place the jack to lift the car so I can put jackstands under the tire-change jacking points? I have a low-profile long-reach floor jack, but have not been able to find sound advice on where to lift each end of the car.
Ken
Old Aug 31, 2013 | 06:47 AM
antalo's Avatar
Originally Posted by krswen
Where can I place the jack to lift the car so I can put jackstands under the tire-change jacking points? I have a low-profile long-reach floor jack, but have not been able to find sound advice on where to lift each end of the car. Ken
Look behind the front wheel, under the chassis. There should be a padding of sorts under which you can put the jack and raise the car. I usually put the jack under the lowest solid metal which is close to the inside of the wheel and it is most of the time under the suspension part.
Old Aug 31, 2013 | 10:35 AM
Leedsman's Avatar
Spring pans are always a good place for a trolley jack. Gets the wheel off the ground/floor quicker too.
Leedsman.
matthewdutcher
Apr 7, 2011 04:22 PM
Osprey
Jun 29, 2009 09:31 PM
JakeB92
Jun 22, 2008 06:05 PM
pbmt
Sep 8, 2007 01:13 AM
brandi
Mar 19, 2007 04:26 PM
