loosing coolant
Old Dec 9, 2007 | 07:37 PM
fibersport's Avatar
Default loosing coolant
2005 T&C Touring, bought it 15 months ago and notied that it was low on antifreeze. Before I left the dealership, I asked them to check it out. They topped it off and did a pressure check and found no leaks. Now a little over a year later, I noticed that the antifreeze is low again, below the cold mark on the tank. I'm not seeing any drips anywhere however when I first start it up, it would sound like water was pouring out somwhere. This would only happen once at the first start. Any thoughts on where the coolant is going? Is it normal to loose some in over a year? Anyone know of any TSB's on this?
Old Dec 10, 2007 | 08:51 AM
moe's Avatar
moe
Default RE: loosing coolant
hey bud it is normal to lose a little anti freeze overa years time.you need to open your hood more!...but if you have a rear ac unit in your van there is a recall of the rear ac/heater tubes.#RC-F01-06.i would call your dealership if you have rear ac and heater.the heater hoses are rotting out causing small amounts of coolant to be lost.have good holidays!moe
Old Dec 10, 2007 | 09:23 PM
fibersport's Avatar
I have been watching it, just wanted to see how low it would go in a given amount of time as well as how long it would take the dealer to notice it when they supposedly give it the once over at each oil change. Thanks for the heads up on the recall.
Old Dec 10, 2007 | 11:36 PM
master tech's Avatar
Do you have a pressure tester, so you can pressure ck the cooling system? If not, have a shop or someone that owns one, to pressure ck the cooling system.
Old Feb 7, 2008 | 01:02 AM
fibersport's Avatar
As an update, took the van in for the coolant leak, found it was the water pump which was covered under warranty.
latreto
May 20, 2012 06:34 PM
jlampitt
11
Feb 10, 2011 09:56 PM
chrycon
Oct 16, 2010 09:25 AM
jquinones
Dec 4, 2008 01:54 PM
shadetreemech
Apr 12, 2008 09:08 AM
