Melted wires -Electric system problem
Old Jan 18, 2017 | 10:30 AM
octopus's Avatar
Default Melted wires -Electric system problem
Greetings,
Looking for help fixing my electric system .This is what happened.
The driver side sun visor kept falling down so in a fit of anger I ripped it off which resulted in the two wires that power the light in the sun visor melting together and shorting. As a result of this a fuse blew.
After this several things stopped working: rear back up lights, radio, A/C
Went to a mechanic and he cut off the melted wires and replaced the fuse. Still, this did not fix anything.
He thinks that possibly the BCM needs replacing. Also, he doesn't know why the rear back up lights don't work, because according to him these generally do not need BCM to function and he thinks they usually have their own fuse, but he couldn't find one.
Anyway, looking for suggestions on what to do next. Would replacing the BCM be the most likely fix?
Thank you for reading.
Old Jan 19, 2017 | 05:08 AM
Vonhofinvule's Avatar
Definitely sounds like the BCM. Not sure what year your van is but I do believe that from 98 or 99 all of the lights are controlled through the BCM.
Old Jan 21, 2017 | 07:37 PM
Raptor 07's Avatar
Need to know what year the van was built to say anything definitive.
Prodjay10
Jun 4, 2016 04:58 AM
andbudzi
Jan 17, 2008 02:04 PM
courtneysebring
Oct 2, 2007 01:08 PM
sumncguy
May 23, 2007 03:43 PM
red97coupe
Jul 2, 2006 05:05 PM
