Multiple Error codes
Old Jun 27, 2021 | 08:20 AM
samvideoman's Avatar
Default Multiple Error codes
Hi,
I have a 2010 Town & Country with the 3.8L engine. In the last 3 months i replaced the spark plugs, spark plug cables and the coil pack. about a month ago, the engine started to stall at a stop light and i had error code PO403, I went to Auto Zone and got a new EGR and replaced it, cleared the codes and took it on a spin, within a few minutes the code came back up, i cleaned up the carbon that was in the tube attached to the EGR, i don't know what to do now? Did i get a bad EGR valve?
I've been driving with the code, it idles ruff some times, the other day i got a new Code P0128, i have noticed that the temp gauge wasn't reaching the middle like it normally did, it was running cooler? i replaced the Thermostat, but that didn't solve my problem, still running cool? Should i replace the Engen coolant sensor?
Also i got a P0305, P0205 code saying Injector 5 - circuit malfunction, so do i replace the #5 full injector?
One thing that i wonder about, is the wiring harness that connects all these things going bad? I seam to be chasing my tail with these replacement parts. Any help or suggestions would be appreciated!
Old Jun 29, 2021 | 06:32 PM
Madmacks's Avatar
P0403 could well be the egr solenoid. This is easy to check. watch this video
. You might find that you only get 8 volts with out the engine running and 10 volts when running.
Old Jun 29, 2021 | 09:08 PM
ggoose's Avatar
What is the age and condition of the battery? Chrysler electronics are sensitive to proper voltages and do tolerate low voltages.
Extortion00
Feb 21, 2016 09:32 PM
Jason1969
Mar 26, 2013 12:13 PM
mrorange
Aug 20, 2009 06:07 AM
mazinger4
Aug 25, 2007 12:47 PM
susan
Cirrus & Breeze
Nov 11, 2006 10:49 PM
