MY05 console led replacment.
Old Aug 19, 2016 | 12:05 PM
minibull's Avatar
Default MY05 console led replacment.
Hi guys, I have search in the forum but I have not found about this console led replcement for a 2005 MY.
Does someone knows the correct led type for the replacement?
Is the led for the buttons light in the upper console.
Thank you in advance.
Old Aug 22, 2016 | 07:48 AM
andyb2000's Avatar
Hi there,
Believe it or not, that IS NOT an LED, it's a regular tungsten bulb with a blue rubber cover over it! I've replaced quite a few of these now and i do replace them with LED.
The main problem/difference is that an LED doesn't diffuse light in the same way, it's a lot more targeted, so you either need an LED with very wide beam or replace with a regular panel bulb.
Search ebay for rectangular LED and you should fine what I've used in the past:
Hopefully that'll help.
Oh and a word of caution, the boards and circuit traces are VERY fragile, I've had to re-make a lot of them with replacement wires because as soon as the soldering iron touches them to remove the old bulb the traces peel off the board and fail.
Old Aug 23, 2016 | 12:48 AM
minibull's Avatar
Tks a lot Andy!
very clear and detailed explanation!
Ony the attached pic not works.. if you can post it again when you have some free time..
Tks a lot.
Old Aug 23, 2016 | 03:00 AM
andyb2000's Avatar
Ah apologies, try again for the image:
Old Aug 24, 2016 | 11:53 AM
minibull's Avatar
changed with a new tungsten but bulb without the blu cap.. the light is better..
rebuilt the two circuit boards..
now it works ok!
tks Andy
jerth
Aug 8, 2021 10:49 AM
MicaX27
May 10, 2014 01:19 AM
Daryl Baines
Dec 29, 2008 06:40 PM
miser_chris
Jul 25, 2007 03:57 AM
rsirois
Dec 15, 2006 02:04 AM
