Newbie advice oils
Old Feb 1, 2016 | 10:17 PM
pepe0151's Avatar
Default Newbie advice oils
Hi new to voyagers.
2005 2.5 CRD Voyager 148,000
Any advice welcome.
Have a whirring noise until i press clutch fully the it dissapears.
Crunches in 3rd 4th .
Now do i change the Oil in gearbox (Manaul transmission 5 speed) .
Will this help before i go diwn the expensive route .
Whst type of oil do i put in gesrbox ?
been reading the last hour and im a bit confused. Thanks in advance , Car came with no history!
Old Feb 2, 2016 | 11:55 AM
Vmaxxer's Avatar
Sounds like clutch job to me..
My clutch was worn at 200.000 and had a sound until pressing the clutch too.
I replaced clutch and all was fine.
Clutch job is pretty expensive at the dealer so I bought the parts on Ebay and found a good and cheap mechanic €400,- parts and labour including the (cranck ?) bearing. Noise has not come back in last 100.000 km
Old Feb 2, 2016 | 04:54 PM
pepe0151's Avatar
So today it crunches in 3rd gear , i cannot get 4th just put in and it just revs. The same with 5th gear . Reverse is ok though.
In neautral it seems to want to serge/lunge forward slightlty . Pulls like a train in gears i have left . Any other help before i get it looked at. Hope its not gearbox😞😞😞😞
Old Feb 3, 2016 | 01:53 AM
tfb's Avatar
tfb
sounds like a replacement gearbox needed. About £100-£200 on ebay. Fit a new clutch and release bearing at the same time.
Richard
Old Feb 3, 2016 | 02:01 PM
Vmaxxer's Avatar
when you can get a gearbox for so little money I would replace that with the clutch and bearing like tfb says.
Strange tho, manual gearboxes seem pretty strong to me. Mine is almost 300K km now and still shifts perfectly smooth
Old Feb 3, 2016 | 05:16 PM
pepe0151's Avatar
Ok . Will start looking for a box , clutch kit and release bearing
So when i get the mechanic to put it in , What gearbox oil 10 w 40
i"ve read on here is that correct. Looks like thre School run"s being done
in 3rd gear . Appreciate all your advice ��������
Old Feb 6, 2016 | 12:07 PM
dieselvoyager's Avatar
Manualgear box need ATF+4 oil think it's 2 - 2,5 litters , it's common if clutch is broken but still working with mabye some noise, hard to change gears ect. I have change a few where the center plate in the clutch was crack and was not abel to disengage 100% also the springs in center was broken.
My 2002 ltd. 2.5 CRD has done 490000km on 3 clutchs first one was slipping 2. and 3. was broken in center.
I change transmission oil every 40000km and use to drive up a ramp to get angel to filler hole on gearbox (to raise oil level a little) never had any transmission problems only clutch.
https://drive.google.com/file/d/1zeb...ew?usp=sharing
https://drive.google.com/file/d/0ByQ...ew?usp=sharing
Brewcity1
12
Oct 30, 2014 10:29 AM
ChryslerEl
Aug 22, 2013 05:00 PM
pestilance
Feb 17, 2012 02:38 PM
whitesmirnoff
Apr 6, 2007 01:31 AM
texas_1628
Jan 5, 2006 03:48 PM
