Power Door switch
Old Mar 1, 2009 | 11:40 AM
actd's Avatar
Default Power Door switch
Next project - hopefully a simple one - is to sort out the drivers side power lock switch. This doesn't work, and the switch doesn't illuminate. I'm hoping it's simply s replacement switch but I need to get the switch out to check that there is power to the switch. I (stupidly) assumed that if I undid the screw that goes through the door release, then this plastic part - along with the power door switch - would simply come out, but sadly doesn't seem to be the case.
Can anyone tell me if the whole door panel simply unclips (apart from the aforementioned screw) or are there any traps waiting for me when I try?
Old Mar 1, 2009 | 03:24 PM
Merlin's Avatar
screws around the outside as well but yes pulls off.
Old Apr 20, 2009 | 07:14 AM
actd's Avatar
Default Front door interior panels.
OK, I've had a look for these, but can't find any screws. The rearmost bottom of the front door panel seems to be held in with something more than just panel clips, so I assume there are screws holding this - where are they and how do I get to them, please.
Old Apr 20, 2009 | 08:55 AM
actd's Avatar
Ah, done it now - well to some extent. Undid the door handle and lock screws and pulled the door trim away at the top, hoping to work my way down, but looked inside the door from the top and the bit of wiring loom hanging loose was a giveaway as to the problem - plugged this back into the door lock switch and now working fine, so didn't even need to buy the switch.
Removed the rear door panel whilst I was at it as this had started to rattle a little - found that there were three panel clips missing so replaced these, cable tied the two lock cable outers together and now all nice and quiet again.
darkcild101
13
Jul 30, 2015 08:08 AM
MrSaratoga
Nov 24, 2013 06:10 PM
dakrt360a
Oct 4, 2013 11:32 AM
@Eddie@
Aug 15, 2012 08:16 PM
stewartsoftware
Feb 27, 2011 03:54 PM
