Preparing Chrysler Voyager Exec CRD 2.8 Automatic for a long towing trip
Old Apr 27, 2012 | 01:38 AM
alexnz's Avatar
Default Preparing Chrysler Voyager Exec CRD 2.8 Automatic for a long towing trip
We are towing a 1,500 kg caravan to Spain and back this summer (~4000 miles). Is there anything else we should consider in addition to the normal servicing? Like better quality oil or automatic transmission fluid, etc? Changing brake pads even if they are still ok for normal usage?
Any towing tips from Chrysler Voyager current/former owners are really appreciated.
Also, does this 2007 model have an oil cooler fitted as a standard? If not, where can I find one in the UK and what would be the approximate damage to my pocket?
Many thanks,
Old Apr 27, 2012 | 03:32 PM
booke23's Avatar
I've never towed with my 2.8 CRD. I imagine the high kerb weight and the high torque produced by the CRD make them an excellent tow car.
I wouldn't bother with any extra servicing. If you tow you should change the transmission fluid occasionally. (every 40,000 miles) But only ever use ATF 4 fluid.
There is both a transmission oil cooler (in front of the radiator...cooled by airflow) and an engine oil cooler (through a coolant heat exchanger arrangement at the oil filter) fitted as standard.
I'd be surprised of you suffered from any serious cooling issues, unless you happen to be towing up a steep mountain in very high ambient temperatures.
Old Apr 28, 2012 | 03:31 PM
alexnz's Avatar
Thank you for your advice. Bought today 5 US Quarts (nearly 5 litres) of ATF + 4. It looks like this thing is hard to get in the UK - I've only managed to find two on line vendors, the total price including delivery was £51.70.
What is the good engine oil to use for this model?
Old Apr 30, 2012 | 02:55 PM
booke23's Avatar
Any 10w-40 diesel engine oil is fine. I used semi synthetic last oil change, but ordinary mineral oil is fine in these engines.
More important is that it is changed as per Chrysler recommendations.
Chrysler Forum Editor
Jul 30, 2015 08:18 PM
Jul 4, 2015 02:18 PM
J K Portland
Sep 12, 2011 03:34 AM
SDHUSKER
Mar 16, 2008 06:59 PM
VFRbeliever
Nov 24, 2007 07:47 AM
