Sponsored by:
Sponsored by:
Pulsing Interior and Exterior Lights
Old 01-13-2008, 10:10 PM
raquettelaker2's Avatar
Default Pulsing Interior and Exterior Lights
My mother has a 2005 T&C Limited with something like 50k miles on it. Especially noticeable at idle, but also there while moving, regardless of engine speed the interior (dash and stuff) and exterior lights contiuously pulse. The frequency is about every 1 second they just dim and come right back. I was thinking alternator or voltage regulator or something? Wanted to get some second opinions if you've got any. Thanks
Old 01-13-2008, 11:29 PM
Default RE: Pulsing Interior and Exterior Lights
possible battery,IPM,Front controler or G300 ground which is at left B piller
Old 10-06-2010, 07:35 AM
BUNNY's Avatar
Hi I have the same problem 2.5 cdr voyager 2001 did you get yours solved if so could you tell me plaese. Thanks Mick
Old 11-11-2017, 06:58 PM
2005 Town & Country Gal's Avatar
I think I finally found the G300 ground wire for 2005 Chrysler Town & Country. There are 2 G300's, one by each door per the video I found.
1. Remove the floor trim that lines the front driver side door.
2. Now remove the plastic housing at the bottom of the door frame where the seat belt comes out. There are some wires with a harness on the floor there. However, per the video that is not the G300.
3. The G300 is the lead that screws into the floor right under those wires! That is it!
4. Clean by removing any corrosion/rust & add dielectric grease.
Here is the link of the video that i found:
"Fixing Power Door Lock Not Working For 2005 Grand Caravan and Town Country".
I have not tried it yet, but my problem is electrical, with door locks, windows, and radio intermittently not working. Hopefully this will be the fix!
carid
07-25-2014 08:30 AM
johnkaracalidis
10-11-2009 01:18 PM
01-14-2009 09:23 PM
05-30-2008 06:04 AM
gschrismon
02-03-2008 07:00 PM
Quick Reply: Pulsing Interior and Exterior Lights
