Rear door stuck
Old Jan 5, 2008 | 08:00 PM
duburban's Avatar
Default Rear door stuck
Hi, I'm trying to fix my friends 1999 town and country. The rear door/hatch stuck closed. Taking off the trim showed that the button would trigger the unlocking arm when switched but it still wouldn't open. Which part should i replace? The latch attatched too the door that locks into the rest of the car?
Old Jan 7, 2008 | 10:02 PM
Default RE: Rear door stuck
stick your arm down the back of the rear hatch panel and pull up on the latch to open the trunk.
Old Jan 8, 2008 | 10:44 AM
moe's Avatar
moe
alike tech said pull up on the handle link right here:> replace the lift gate latch you should be fine as long as your handle still works.moe
Old Jan 8, 2008 | 05:40 PM
duburban's Avatar
Anyway to check the handle before i reinstall? Do you happen to have a part number for that liftgate latch? Thanks for the help!
Old Jan 8, 2008 | 07:35 PM
moe's Avatar
moe
heres your part # for the latch.4675776, once you have the latch off double check your handle make sure the rod clip didn't pop off.if it did you may have found your problem.lube the latch up and reinstall the rod.moe
provench
Oct 7, 2021 04:42 PM
Boston300
Sep 15, 2011 08:12 AM
morgoth
12
Dec 31, 2010 05:39 PM
antonylord
Oct 22, 2009 06:05 AM
jaelli
Dec 2, 2007 10:39 AM
