Serpetine belt slips in the rain
Old Aug 1, 2016 | 09:45 AM
POP TOP's Avatar
Default Serpetine belt slips in the rain
On a 2007 Town and Country in the rain I loose PS, AC and Alternator as the belt slips. I've Changed the belt and tensioner with no help. What could be causing this?
Old Aug 1, 2016 | 02:48 PM
Your next best renewal is the Alternator pulley as it looks like its became shinny smooth due too slipping too long. You can however roughen up the muli-faces on the pulley with emery paper but its said not too last long. I'm sure the PS (power Steering) uses another belt.
Old Aug 5, 2016 | 02:38 PM
Vonhofinvule's Avatar
There are also a couple of other things to check for. Look towards the rear of the engine compartment and look for the wiper tray drain pipe, make sure its not dripping onto the serpentine belt. That was a problem with my girlfriends 2005 and it had me demented, just couldn't figure it out until I stood there one day with a hosepipe spraying water on the windshield.
As goggs said you want to roughen up the pulley face on the alternator but also hit the AC, power steering and most importantly the crank drive pulley. Its also worthwhile cleaning all the pulleys with isopropylene alcohol just to remove any residue!
Old Aug 5, 2016 | 04:41 PM
amishapatel0071's Avatar
Old Jan 8, 2017 | 07:40 AM
Mopar for life's Avatar
napa and carquest make a problem solver belt kit for this. It is a 2 sided grooved belt an pulleys to replace the smooth ones cleaning will not work
Old Jan 24, 2017 | 10:09 PM
xmanmta's Avatar
Gates has a repair kit it comes with a new belt, idler pulley and tensioner maybe $175.00.
or you can check under the van to see if the splatter shield is still there.
i know the Gates way for me work out with know problems after i installed it.
Green300M
Mar 8, 2016 05:45 AM
bcartman_2
Jul 30, 2009 07:34 PM
ph4cars
Nov 18, 2008 08:12 AM
Aquinas
Apr 18, 2007 01:59 AM
Nov 16, 2005 04:58 PM
