starting problem
Old Sep 9, 2015 | 07:06 AM
graham payne's Avatar
Default starting problem
Hi all
Wondering if someone can offer some advice or info here. I have a 2006 grand voyager LX 2.8 crd uk model. I have been experiencing starting problems for a while, from cold it is taking up to 10 seconds of cranking before it starts, if restarting immediately there is no problem, however when the engine has warmed up and is left for a few minutes, when I try to start it, it attempts to fire then just continues to crank over, this needs to be attempted several times before it fires into life. (sometimes it seems to start sooner if left for a minute between attempts. It runs fine once started, and the battery is new. I have done a back leakage test on the injectors, they were good, also the glow plugs are functioning ok. I then performed a back leakage test on the pressure relief valve on the rail, it passed 105 ml of diesel in one minute,(on tick over) I understand that this should not pass diesel under normal circumstances and that this can lead to starting issues. I would be grateful if someone could clarify this. Thanx
Old Sep 9, 2015 | 11:08 AM
tfb's Avatar
tfb
correct, that's an over pressure valve and shouldn't leak fuel under normal conditions.
If it is leaking then it can be the cause of starting and/or cutting out issues as the pump then struggles to maintain/raise fuel rail pressure
Regards
Richard
Old Sep 9, 2015 | 12:12 PM
Default Thanx
Cheers Richard for the reply, I am happy to spend the money and have the repair done now.
kind regards Graham
Old Sep 9, 2015 | 03:49 PM
Best question and answer to it in a long while and you more or less got it right.
But..Ah..em..wait....having the repair done...That's another story..
Will it be another injection pump required. What's the odds...
Good luck and stick to the answer.
Old Sep 10, 2015 | 07:20 AM
Thanx goggs got the part and all seems good so far I'll keep you posted
And thanx Richard for confirming my suspicions
Old Apr 10, 2016 | 02:55 PM
Hows your car after changing the relief valve Graham...It certainly was a good quick thread under fuel rail pressure and starting.
safetyman
Sep 16, 2008 01:46 PM
89newyorker
Jul 19, 2008 08:55 AM
Scruffy
Feb 2, 2007 04:35 PM
mailmule
Dec 15, 2006 03:33 PM
mailmule
Dec 7, 2006 07:04 PM
