Starting problems...sometimes
Old Apr 8, 2019 | 03:58 AM
Matt from Oz's Avatar
Default Starting problems...sometimes
My 2003 3.3 L Grand Voyager has starting problems. The starter motor always cranks, but under certain conditions it can take too long to fire up. When the engine is cold, no problems. Cranking after engine is shutdown, but within about 10 minutes...ok. But after leaving the engine off for between about 10 minutes to a couple of hours, it takes about 5 to 10 seconds to fire up. Why?
Old Apr 8, 2019 | 10:17 AM
REBEL59's Avatar
It's 16 yrs old...any CEL lit on the dash? What maint has it had beyond oil changes? Good chance of a weakening fuel pump.
Old Apr 9, 2019 | 03:31 AM
Thanks for your reply. No CEL lit. Engine fully rebuilt about two years ago. Fuel filter replaced last week.
I changed the fuel pump assembly about three years ago due to my fuel gauge jumping up and down intermittently. I guess the pump might be a cause, but I thought this would cause starting issues all the time?
Old Apr 9, 2019 | 06:50 AM
REBEL59's Avatar
The GUESS was fuel pump IF it was the original unit. NO CEL? Then I guess it is time to pull out a test light or DVOM to test for power at the coil pack or even the fuel pump relay in the fuse panel WHEN the situation occurs.
When this happens, have you tried just turning the key to the run position, waiting a few seconds and listen for fuel pump whine(couple seconds) and then doing again before cranking to make sure it is NOT a fuel "bleed down" situation or even loss of electric current to engage the fuel pump?
Old Apr 9, 2019 | 07:39 AM
Thanks. I’ll try what you have mentioned and keep you updated.
2007Pacifica4L
Dec 17, 2019 03:50 PM
maintenance
Apr 30, 2015 05:15 PM
Mama2Saigai
Jul 24, 2013 01:46 PM
Chris Tyas
Aug 24, 2009 07:02 AM
moose7171
Jun 4, 2008 04:59 PM
