ticking sound
Old Oct 22, 2010 | 03:59 PM
bugsbunny16374's Avatar
Default ticking sound
i own a 2001 t&c limited with a 3.8. It has a ticking sound in the motor. Only does it when the engine is under a load. Doesn't make the sound when coasting or sitting at a stop sign or traffic light. Sound doesn't go away either even after driving all day. Wouldn't think it's a valve or lifter, it would do it all the time. Could it be a problem with injectors?
Old Oct 22, 2010 | 09:45 PM
TNtech's Avatar
Probably a lifter. Tick or Knock ? Single tick or multiple ticks? Does it have enough oil in it? How often do you change it?
Old Oct 23, 2010 | 02:53 PM
It's definitely ticks and there are multiple ticks. Oil level is ok. just changed it 1k miles ago and it gets changed every 3k. I thought that to but wouldn't it make that sound all the time whether coasting or under load? I put in some Lucas oil treatment and that didn't work.
Old Oct 23, 2010 | 04:47 PM
TNtech's Avatar
OK, mileage?
Old Oct 26, 2010 | 05:32 PM
162,900 and other than the ticking sound, runs like brand new!
Old Oct 29, 2010 | 09:26 AM
dugger's Avatar
I had similar ticking sound on my '97 t&c. Turned out to be serpentine belt. Using the old "bar of soap trick" (hold soap bar on grooved side of belt for a second or two with engine running). If sound disappears, it's the belt. In my case new belt fixed the problem.
dougsdad
11
Apr 20, 2014 11:23 PM
Arthur Aghakhabian
Jul 25, 2012 08:24 PM
organist57
37
Aug 29, 2010 01:56 PM
HeyMoe
Jan 6, 2009 10:18 AM
vw.fe2o3
Cirrus & Breeze
Apr 22, 2008 08:47 PM
