Transmission light on after battery change
Old Feb 5, 2014 | 11:39 AM
richjones19772000's Avatar
Default Transmission light on after battery change
Hi guys, just fitted a new battery in my 2002 2.5CRD voyager, took it out for a quick spin and the engine management light came on and the car also went into limp mode, stop for a few mins and the light was still on but it was driving normal. Had the bonnet open whilst I was changing the battery and it was raining pretty heavy any chance a bit of water could be the culprit ?
Cheers
Old Feb 5, 2014 | 02:24 PM
tfb's Avatar
tfb
try doing the key dance to see what fault codes are logged.
Regards
Richard
Old Feb 5, 2014 | 04:04 PM
Regards
Richard
is that's the on/off on/off on/off method?
Old Feb 6, 2014 | 01:51 AM
tfb's Avatar
tfb
yep, thats it
Old Feb 6, 2014 | 04:46 AM
yep, thats it
Hi i did the key dance. The code that was shown was P010.0?
Old Feb 6, 2014 | 09:05 AM
tfb's Avatar
tfb
P0100 is the Mass Air Flow sensor.
Time to get a multi meter out and check some of the voltages.
It will report a fault if the reference voltage is below 4.8 or 5.2V (but most likely other items would report faults if that was the case)
It will report a fault if the sensor voltage is less than 0.2V or above 4.5V
It will also report a fault if the sensor voltage does not match what it expects given the current engine load, this can be the hardest to diagnose as it may not be the MAF, eg an air leak in the intake system can cause this.
I'll ulpoad the MAF connector details later
Regards
Richard
Old Feb 6, 2014 | 10:20 AM
Default Maf
Regards
Richard
Thanks for that Richard, would this also cause the car to into limp mode? for a brief spell yesterday it had minimal power and then it came back, been fine since?
Old Feb 7, 2014 | 01:51 AM
tfb's Avatar
tfb
MAF connector is here
https://skydrive.live.com/redir?resi...nt=file%2c.pdf
and yes, it would cause it to go into limp mode
Regards
Richard
darkcild101
54
Oct 2, 2014 05:13 PM
Edengweiss
Jun 19, 2014 05:34 PM
littlestoney406
Feb 15, 2011 11:05 AM
pdh
Apr 21, 2009 04:16 PM
jmm
Aug 31, 2006 08:05 PM
