Turn Signal Stays On
Old Feb 26, 2011 | 08:10 PM
acmectec's Avatar
Default Turn Signal Stays On
I have a 98 T&C. Occasionally, the left turn signal will stay on. The arm comes back up but the indicator light on the dash and the outside light stay lit, even after the car is turned off. I have tried jiggling the switch and turning the flashers on . It eventually goes off but it doesnt seem to be consistent enough to tell what does it.
The A/C compressor also whines. It works but just makes a noise. Can I replace a bearing without pulling it off? Is it a bearing or do I have to replace the clutch?
Old Feb 27, 2011 | 06:35 AM
gn300's Avatar
Sounds like the switch, is the steering wheel centered?
Old Feb 27, 2011 | 10:08 AM
possible flasher relay is bad
Old Mar 1, 2011 | 09:24 PM
acmectec's Avatar
Thanks Tech!
Is the relay the same as the flasher? Is there a way to test it?
Thanks again!
Old Mar 1, 2011 | 10:08 PM
yes its called a flasher relay U wont be able to test things inside it no Unless u want to get a wire diagram and check the inputs and outputs from the relay be my guest.
swittie
Nov 10, 2020 02:02 PM
VFRbeliever
Jan 23, 2011 05:03 PM
GSKI
13
Sep 11, 2007 09:33 AM
alan
Jun 11, 2007 09:27 PM
pinecone
Aug 25, 2005 01:13 AM
