Voyager 2.4L power steering belt
Old Feb 10, 2021 | 06:00 AM
PepperTX21's Avatar
Default Voyager 2.4L power steering belt
Hello everyone !
Have anyone work on 2.4L engine replacing drive belts, alternator &AC and power steering belt, alternator serpentine belt was really easy but I had an issue with the power steering belt where you have to loosen three bolts and the adjuster bolt to release tension, I was able to removed the belts but when I tried to tension the new belt back up , the adjuster bolt wasn't doing its job, I probably have a bad adjuster because no matters what direction I turn it to , it did not put tension to the belt.
I managed to put some tension by pushing the pump up and tighten the two bolts, but I think it is still somewhat loose.
Any ideas or suggestions for this issue? Thanks
CarComp
Feb 13, 2018 06:29 AM
keyology
Aug 20, 2011 11:44 PM
htran2313
Aug 20, 2011 11:43 PM
jimratz
Sep 25, 2009 11:56 AM
evigilu
Mar 7, 2008 08:15 AM
