Voyager 98 will not start
Old Apr 28, 2007 | 05:02 PM
sparkboy21's Avatar
Default Voyager 98 will not start
Hi All from a new member
I have just purchased a 1998 Voyager LE and on 2 occations now it will not start.
When you try to start it will run for about 5 sec and just cuts out. It will do this 3 times then you can't start it at all.
The starter motor will not turnover at all and the milage does not light up at all. I was told to remove the battery and leave it
for 15min and then try it again. I did this and it did not start so I left the battery off or a couple of hours. When I tried it this
time it did start OK.
The other problem I am having is a shudder in the engine at about 2500 revs to 3000 revs when pulling away or trying to overtake.
It is as if the engine is missing.
Can any one give me some advice on the above problems.
Regards, Ian
Old May 8, 2007 | 08:25 AM
james edward's Avatar
Default RE: Voyager 98 will not start
hi am new member aswell. and we have got the same car with exactly the same problem. had the same problem with it 2 1/2 yrs ago aswell took it to main dealer cost us 500 pound sterling and now we having exactly the same problem again. we have bought numerous new batteries as thought it could be the battery and being drained somehow. we have had the battery off while we fully recharged it but it hasn't made a difference. wish we could help you but we at a loss too. will keep you posted if we do manage to get it sorted. sorry cud'nt be more help. cheers james.
Old May 8, 2007 | 09:54 AM
kunzite's Avatar
Hi!
Just in case:
We had a problem that (maybe) has some similarities; visible here.
But due to the nature of the incident, the symptoms to others could be just anything
https://www.chryslerforum.com/m_7700/tm.htm
It was a problem with the fuse & relays box.
Good research.
Jacques
Old May 8, 2007 | 10:09 AM
thanx we will have to check it out will keep in touch. james.
ikappa
May 23, 2022 04:44 PM
jbda
Cirrus & Breeze
Apr 1, 2013 11:09 AM
tmerila
Aug 28, 2009 02:45 AM
golfdoctor3
Jan 19, 2009 11:11 PM
kunzite
Mar 7, 2007 07:05 PM
