Sponsored by:
Sponsored by:
oil change
Old 12-27-2014, 03:33 PM
davidgossett's Avatar
Default oil change
I have a 2009 town country. I have changed the oil how do I get the message off where the odometer is located? Thanks
David
Old 12-27-2014, 06:25 PM
georgef's Avatar
From the owners manual:
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following steps.
1. Turn the ignition switch to the ON position (do not start the engine).
2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps.
If you don't have an owners manual you can download one here: http://www.dodge.com/en/owners/manuals/
George
Old 12-27-2014, 08:14 PM
Just what I needed to know. Thanks again
David
Old 01-20-2017, 12:07 PM
hytec's Avatar
I've performed this procedure five times, each time ensuring it was completed within ten seconds, though not less than eight seconds. However, the message doesn't reset.
The van is a 2014 T&C Touring L with a Braunability wheelchair conversion, if that makes any difference. Any suggestions would be appreciated, thanks.
Old 01-20-2017, 04:52 PM
ChryslerCares's Avatar
Hi hytec,
If you'd like to PM your VIN, I can check to see if there's something else we can do to help you reset the message.
Kori
Chrysler Social Care Specialist
Old 01-24-2017, 07:17 AM
hytec's Avatar
Kori, I PM'd the VIN Saturday as you asked. Have you been able to determine anything that may help solve this issue? Thanks, Hank
Old 01-24-2017, 08:53 AM
Hi Hank, I responded to your message a short time ago, I apologize for the delay.
Kori
Old 01-25-2017, 03:32 PM
hytec's Avatar
Kori, the proper procedure worked fine.
The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time.
As has been said many times: "Too Soon Old, Too Late Smart." <gr>
Thanks, Hank
Old 01-25-2017, 03:46 PM
georgef's Avatar
...The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time...
Thanks for the update, it could help someone else making the same mistake.
15951a\
11-24-2021 06:40 PM
Nick1981-1
08-19-2013 05:27 PM
flaxman
09-05-2011 02:10 AM
popymoose
11-12-2007 04:58 PM
2006 300C
02-26-2006 12:44 PM
Quick Reply: oil change
