2000 cirrus 2.4L with 3 cylinders with no compression. Cause???
Old Mar 11, 2008 | 08:12 PM
mrunner13's Avatar
Default 2000 cirrus 2.4L with 3 cylinders with no compression. Cause???
I have a 2000 Chrysler cirrus(2.4L DOHC_101,000 miles)that suddenly stopped running. Found 3 cylinders(# 2,3 and 4)with no compression. Removed head and found one exhaust valve in each of the three no compression cylinders with a dime size hole. The other 3 valves in each cylinders looked ok. Any idea what caused these holes(looked like burn thru)???
Old Mar 14, 2008 | 10:43 PM
john777's Avatar
Default RE: 2000 cirrus 2.4L with 3 cylinders with no compression. Cause???
Wow....All 3 failing at the same time seams like something catastrophic happened. Did something come loose in the engine and chew the valves up? I don't think they just wore out like that at the same time.
Old Mar 15, 2008 | 05:27 PM
moe's Avatar
moe
look for blocked cat'convertor,or stuck injectors dumping fuel.and check engine light before.....had to be.
nickincam
Dec 2, 2023 06:42 AM
albentley
May 1, 2011 05:45 PM
julia giron
Apr 20, 2011 01:18 AM
jameslee522
Oct 18, 2007 04:24 PM
paul.siwek
16
Jul 29, 2007 10:27 PM
