Aftermarket stereo install - wiring help needed
Old Jun 18, 2007 | 06:31 AM
opk's Avatar
opk
Default Aftermarket stereo install - wiring help needed
Hi. I have a 200 Cirrus. I bought it last month with the factory am/fm/cassette and CD changer controls, but no changer. The factory head unit has a joystick control for the fader/balance.
I bought a stereo at a local place andthe correct year/modelScosche wire harness adapter from Walmart. Wired it correctly except did not hook up the amp pwer wire because I did not think the car had a factory amp. The aftermarket head unit has several pre-outs.
The stereodoes not playvery loudlywith minimal bass even at high volume/bass settings, and the front door speakers so not seem to play at all - only the dash speakers and rear deck speakers seem to work.
Its worth noting I bought a factory CD deck from ebay and it plugged in fine and works BUT only the rear speakers work. The seller is going to give me a refund but claims he tested it and it worked fine.
What gives? What am I doing wrong...I just want to play CDs in the car...Thanks...
Old Jun 18, 2007 | 08:12 AM
Default RE: Aftermarket stereo install - wiring help needed
Wired it correctly except did not hook up the amp pwer wire because I did not think the car had a factory amp. U wanted to know whats wrong there ya go.
[IMG]local://upfiles/1033/20086AB29C6248D089A6A300FD9D10A5.gif[/IMG]
Old Jun 18, 2007 | 06:44 PM
opk's Avatar
opk
Ok...thanks very much...that helps immensely.
Onefollow-upquestion...the wire harness adapter I bought takes speaker level output from the aftermarket stereo to the amp...but an adapter I saw this morining while researching the problem online takes the pre-outs from the aftermarket unit to the amp. Is it ok to take speaker-level outputs and put them thru the factory amp?
I had an Exploder with a factory amp and had to bypass it to run an aftermarket stereo as I recall...so I just want to make sure I haven't or won't fry something.
Jason1969
Jan 11, 2016 04:47 AM
christopher0227
Nov 11, 2013 11:24 AM
ctconline
Aug 25, 2013 08:29 PM
mark44004
Nov 11, 2010 09:52 PM
Yodastoe
Feb 1, 2009 10:32 AM
