Bolt fell in timing belt assembly - Cirrus 99 LXI
Old Aug 20, 2011 | 08:54 PM
JerseyGirl's Avatar
Default Bolt fell in timing belt assembly - Cirrus 99 LXI
I was replacing the valve cover gaskets when a bolt fell into timing belt assembly. I cannot find it. I already stuck a telescopic magnet inside the assembly, but haven't had any luck so far. Opening/removing the timing belt assembly would require me to remove the main pulley first. It's so much work, so I'd rather not do that. Do you guys have any suggestions?
JerseyGirl's Avatar
Old Aug 20, 2011 | 09:32 PM
not to much to say if u cant it fishing then u have to go under water to get it then
Old Aug 21, 2011 | 10:41 PM
JerseyGirl's Avatar
Isn't there an easier way to open the assembly?
Old Aug 21, 2011 | 10:42 PM
JerseyGirl's Avatar
would you consider it unsafe to start the engine regardless? just to see what happens?
Is there a way to rotate the crank shaft manually to see if the bolt just feeds through?
lost-in-space
Cirrus & Breeze
Dec 5, 2014 10:36 PM
buddy7
Jul 26, 2011 01:04 AM
binky42
Cirrus & Breeze
Jul 20, 2011 06:10 PM
rossj71
Cirrus & Breeze
Jan 23, 2011 07:34 PM
chum
Jun 8, 2009 08:30 PM
