1991 new yorker 3.3l radiator fans /fans
Old Jul 22, 2020 | 10:43 PM
dsnap69's Avatar
Default 1991 new yorker 3.3l radiator fans /fans
Have an overheating issue. It overheats because fans or not coming on.
If I jump pins 30 and 87 on relay box, fans spin up and temp drops extremely fast.
I replaced the 2 wire temp switch.
some interesting things.
1. Air conditioner does not come on when pressing AC switch. So fans don't come on.
2. If I disconnect 2 wire coolant temp switch, the check engine light comes on, but the fans still don't come on. But as I understand, they are supposed to turn on when that connector is disconnected.
3. With both fan connectors and relay disconnected, I get following.
If I put meter on continuity and place red prob into black wire pin on either fan connector and place black probe on any car ground I hear beep.
If I place red probe into green wire pin on either fan connector and black probe to any ground I hear NO beep, as expected.
If I move black probe to pin 87 on relay box, I hear a beep, as I would expect.
Here's where it gets strange to me.
If I plug one of the fan connectors to fan(doesnt matter which one). So red probe is still connected to pin that green wire is at, now if I touch black probe to any ground I HEAR A BEEP.
If I disconnect fan the beep goes away.
the fans are 2 wire, and tied together. So no hi and low speeds.
Any ideas anyone.
thanks
Douglas
Ericlaptonight
Aug 27, 2019 06:05 PM
nickstoyz
Aug 11, 2015 10:07 AM
luckynotsmart
Mar 5, 2014 06:40 PM
keithm
Aug 5, 2013 12:09 AM
vlsgmc
Apr 4, 2008 09:26 PM
