2006 sebring 2.4L 80k miles
Old Jun 25, 2021 | 10:33 AM
ace111781's Avatar
Default 2006 sebring 2.4L 80k miles
Ok a week age it jerked 3 times and stalled.. then wouldn't start again. It sent code for camshaft.. replaced it still nothing. Then saw timing belt was missing teeth. Had it replaced. Car now starts . Then had the crank sensor and spark plugs replaced aswell.. the car now runs but not great.. doesn't make any sounds but it idles rough its stalls on stop 1/2 of the time and sometimes hard shift on 2nd gear.
No codes but engine light is on.. was told it is map sensor or fuel pump by my father.. help plz I need my car running good since I am the care taker of 2 elderly bed ridden ppl..
Old Jun 25, 2021 | 02:03 PM
ggoose's Avatar
I would suggest rechecking the timing belt to be certain the marks all line up. The rough idle tells me the timing may be off by a tooth.
Regarding the plugs, only Champion or NGK copper plugs are recommended. Platinum/Iridium plugs do not seem to work as well as the copper ones. The spark plug wires are probably due, should be changed out every 60,000 miles (every other spark plug change).
My preference is OEM/mopar sensors only for the cam and crank sensors. I have problems with auto parts store sensors right out of the box.
If the engine light on, there are codes. May need a different code reader to pull the codes. A number of auto parts stores will read the codes and give you a printout.
Keep your focus on the timing belt, plugs and sensors at this time. The motor was running until the timing belt issue so start with the recently replaced parts.
Old Jun 26, 2021 | 10:15 AM
ace111781's Avatar
Default update
Ok replaced the map sensor yesterday n put the old cam sensor in.. it runs alittle better but still stalls when parking or going into rev to drive n drive to rev. 1st to 2nd gear still putters every so often but let off gas and it shifts smoothly. At stop the idle is still tough ...
Then noticed the mechanic broke 1/2 the case around the code reader
Old Jul 1, 2021 | 10:06 AM
ace111781's Avatar
Default codes
Ok got codes
0172
0016
0440
Replaced therostat due to overheating..
But will get new o2 sensor this weekend. Then saw i will have to do a reset by disconnecting battery for an hour. Hopefully this works to get everything inline
Old Jul 1, 2021 | 08:00 PM
ggoose's Avatar
Recommend only use oem/NTK/Denso O2 sensors. Other O2 sensors do not play well with Chryslers. Bosch are more miss than hit, I suggest avoiding them.
Old Jul 5, 2021 | 06:30 PM
ace111781's Avatar
Default replaced o2
Ok the codes 0440 and 0172 are gone but still getting code 0016 and code 0300.. I have replaced the cam n crank sensor n spark plugs but still getting these codes.. It has rough idle and stalls at stops.. does start back up right away .. it also has started to over heat but I have replaced thermostat and still having a over heat issue after 15mins of driving..
Old Jul 11, 2021 | 07:52 AM
ace111781's Avatar
Default stil getting nowhere
Was told it has to b electronic since when I reset the ecu it runs perfect for a few minutes be4 all the issues come back.. had 3 mechanics look at it and none could figure it out.. I love my car but getting to the point of junking it and getting a new car which I can't afford.. bc I have replaced so much n its still not running right ...
Harley44howard
Nov 10, 2020 07:04 PM
Mrbrucie22
Jan 6, 2015 12:08 PM
dee crazie
Oct 20, 2013 09:55 AM
smokie44
Oct 20, 2011 09:40 PM
adsebring
Jun 20, 2008 08:25 AM
