2008 AWD Slipping when turning from a dead stop
Hey All, I bought a used 2008 Pacifica Limited AWD 4.0l and going through catching up all the maintenance like I do with any used cars I buy.
I have done the timing belt and had the transmission filter and fluid changed. I do show on the Carfax that the rear differential had been serviced at 101k miles but the PTU had not been serviced. I'll have to get to that soon. My wife did notice that it seems to kind of lag then break free when leaving a a stop. I took it out to replicate the issue and sure enough it does happen only from a dead stop and only when the steering wheel is turned.
I did have a little time to crawl under it and disconnect the overrunning clutch solenoid and take it for a couple laps around the block. Of course the AWD light is now on. I can not get it to lag like it was.
So at least it doesn't seem to be the transmission itself.
In going through the service records I found a shop that performed an inspection on it and called to see if anything was found. They said the coupler was torn but not a big deal. I looked at the driveshaft and can not find a torn coupler but I am able to wiggle the driveshaft easily between the 1st and 2nd sections of the shaft but am not sure if that is normal or an issue. I did also notice fluid where the differential and viscous coupling mate. Just guessing that the viscous coupling is leaking fluid and is damaged. So, looking for a little knowledge of these parts in the AWD systems. What do I do next to diagnose and fix the issue? Any advise would be a big help. Thanks!
Mopar_Mikey
Sep 14, 2016 01:55 PM
Loki Sunrider
9
Mar 6, 2008 11:29 PM
